I thought Id come on here and Post Up , Ive laughed at some of the comments of the '' Experts ''........
1) You DONT NEED a kit shipped in from the USA with new driveshafts etc as Its uneccesary and expensive and TBH The big front bracket doesnt fit well or properly ( I have checked on one fitted to a Uk bus and it has had to modified to line up the gearbox properly )
2) As Axl has done you can use the original bracket BUT instead of washers packing it out I have trimmed away more of the original early bay bracket ( In stead of a small V like Axels you make a larger U shape ) This then enables you to mount the original early bay frt steel bracket to the front of your new 1302/3S box onto the original factory mounts
NOTE : I had to redrill the two front mounting holes on the very front of the Early bay gearbox bracket to line up with the original early bay frt gearbox rubber mount as mounting the bracket to the gearbox face instead of spacing it off moves the bracket backwards by 20mm
3) For the record its best to fit a 68 to 71 early beetle nose cone to the front of your new 03 box ( 02 boxes had them as standard ) This gives you a flatter profile to bolt your bay front gearbox bracket too
4) You CAN USE standard bus drives shafts as there the correct length and more importantly Original German parts not **** imported from Mexico.......
5) You CAN use standard beetle inner Cv joints ( Get good quality German ones NOT repro **** ) All you have to do is undo the circlip holding the original bus CV joint on slid it off making sure the spring washer is still on the driveshaft and then slide the new beetle one back on again ( Yes they will take the power and strain that a bus requires ) and refit the original circlip
6) You can use one of Axls bowden tube extenders , I personally modified the original beetle bracket and bus bracket together to make it all fit and used a longer beetle bowden tube
7) I modified the length of the front gear linkage thats above the front axle by I think 26mm by adding a section of tubing but Axls idea is just as good
8) Everybody do your research and do it this way, and STAY AWAY from unscruplous traders who have never even done this conversion themselves YET are trying to sell it off to the public at grossly inflated prices and its not even been Road tested , Yet alone finished
9) Finally I did this conversion 11 years ago when '' Experts '' said it couldnt be done and I have put over 40,000 miles on it and if You've ever convoyed with me You'll no I dont hang around :lol:
Ive used genuine german parts and have been very successful with it
As You were :mrgreen:
