Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
If you have bought, sold or gained information from our Classifieds, please donate to Early Bay and give back.
You can
become a Supporting Member
or just
click here to donate
For Sale & Wanted section
Early Bay Vans for Sale & Wanted
1969 VW Early Bay tin top.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Whitewater" data-source="post: 649065" data-attributes="member: 31895"><p>Savannah beige / White top half. Left hand drive. Non-walk through. This bus has been with my family since 2009, after I bought it from a young couple who had imported it from California via Kieft & Klop in 2006 but had a baby on the way and could not afford to keep it (the bus, not the baby).</p><p>This is a solid bus and have videos to show recent renovation work (bare metal respray / all new window and door rubbers /re-undersealed). Apart from general maintenance, I have had relatively little work carried out since purchase as it has been so reliable. I did have a new short engine approx. 2016 and have since had a new carburettor (2023). Disc brakes were fitted to the front end in approx. 2008. Little else has been altered and the inside was already home-converted from original microbus set-up on purchase with a mains hookup /circuit breaker / cupboards / sink / storage box /rear seat belt / rock n’ roll bed / blue and white check curtains and rear bench seat covers. Garaged from Oct-April every year. New headliner and some door cards and carpets from Bromsgrove Auto Trimmers. A new battery plate has been welded in, as have two footwell patches, the lower rear corners, and the front edge behind bumper has been replaced. None of the traditional oil leaks present, so your driveway can relax.</p><p>Only negative points are a small tear on the passenger seat base, and the ignition key is not an original. The speedo is erratic and the fuel gauge too. She also needs a couple of new door cards (sliding door and rear door). Has only done limited miles in recent years and reason for sale is that my family have now outgrown its sleeping capacity, and I will be sad to see her go. Green ‘Just Kampers’ Drive Away Awning included. Tax exempt and MOT exempt but has a 7 month MOT. Available to view in Worcestershire. £15,500</p></blockquote><p></p>
[QUOTE="Whitewater, post: 649065, member: 31895"] Savannah beige / White top half. Left hand drive. Non-walk through. This bus has been with my family since 2009, after I bought it from a young couple who had imported it from California via Kieft & Klop in 2006 but had a baby on the way and could not afford to keep it (the bus, not the baby). This is a solid bus and have videos to show recent renovation work (bare metal respray / all new window and door rubbers /re-undersealed). Apart from general maintenance, I have had relatively little work carried out since purchase as it has been so reliable. I did have a new short engine approx. 2016 and have since had a new carburettor (2023). Disc brakes were fitted to the front end in approx. 2008. Little else has been altered and the inside was already home-converted from original microbus set-up on purchase with a mains hookup /circuit breaker / cupboards / sink / storage box /rear seat belt / rock n’ roll bed / blue and white check curtains and rear bench seat covers. Garaged from Oct-April every year. New headliner and some door cards and carpets from Bromsgrove Auto Trimmers. A new battery plate has been welded in, as have two footwell patches, the lower rear corners, and the front edge behind bumper has been replaced. None of the traditional oil leaks present, so your driveway can relax. Only negative points are a small tear on the passenger seat base, and the ignition key is not an original. The speedo is erratic and the fuel gauge too. She also needs a couple of new door cards (sliding door and rear door). Has only done limited miles in recent years and reason for sale is that my family have now outgrown its sleeping capacity, and I will be sad to see her go. Green ‘Just Kampers’ Drive Away Awning included. Tax exempt and MOT exempt but has a 7 month MOT. Available to view in Worcestershire. £15,500 [/QUOTE]
Verification
Post reply
