Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
1971 Acoustic sound panels above engine
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Wannabay" data-source="post: 616490" data-attributes="member: 465"><p>I'd also recommend the Rackhams engine board, with noisekiller lead sandwich which is foil faced and self adhesive, it is a sheet of lead sandwiched inside acoustic foam and is 12mm thick overall</p></blockquote><p></p>
[QUOTE="Wannabay, post: 616490, member: 465"] I'd also recommend the Rackhams engine board, with noisekiller lead sandwich which is foil faced and self adhesive, it is a sheet of lead sandwiched inside acoustic foam and is 12mm thick overall [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
