froggy
Got all the parts to fit my hook up but do i really need a consumer unit?
Cant i just run my hook up via an in-line RCD and then attach the sockets to this, almost the same way an extension is wired?
http://www.spares2you.co.uk/Caravan...ited/PORTABLE+MAINS+:++3+x+13+AMP+SOCKET.html
In effect i will have the above circuit but spread out through out van. I dont intend to wire any 240V lights so would only use 1 MCB and only plan on using a few sockets. If i need to the i can also use a 4 gang extension lead.
Cant see the point of a consumer unit when an in-line RCD does the same thing. Worst case scenario is i fit a fused spur before the sockets.
