Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
3mm ply
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="sacramentobay" data-source="post: 441558" data-attributes="member: 19530"><p>Hi, the middle and rear sections of the ply are pretty much square (give or take a few mm).</p><p>The cab panel width is approx 1330mm at the centre brace by the sliding door, and approx 1206mm at the windscreen. The overall length, at the longest point (centre brace to windscreen) is approx 904mm. The only difficult part is cutting the ply to fit around the sunvisor brackets and around the rear view mirror, but you could make a cardboard template before cutting the ply.</p><p>Hope this helps? Dave</p></blockquote><p></p>
[QUOTE="sacramentobay, post: 441558, member: 19530"] Hi, the middle and rear sections of the ply are pretty much square (give or take a few mm). The cab panel width is approx 1330mm at the centre brace by the sliding door, and approx 1206mm at the windscreen. The overall length, at the longest point (centre brace to windscreen) is approx 904mm. The only difficult part is cutting the ply to fit around the sunvisor brackets and around the rear view mirror, but you could make a cardboard template before cutting the ply. Hope this helps? Dave [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
3mm ply
