Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Gallery
68 South African singlecab
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="whale156" data-source="post: 627334" data-attributes="member: 31995"><p><a href="https://postimg.cc/VdvNSC1M" target="_blank"><img src="https://i.postimg.cc/VdvNSC1M/20210620-134642.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></a></p><p> </p><p></p><p>Thanks. Here is a closeup of mine after i took the pedals off and tried to persuade the shaft out, I managed to bash it a few inches before it seizes tight (even this would not have been possible with the floor fitted). There is a bit of a key/tab on each end of the shaft which you might just make out on the visible end. I can't remove these so far as I know though since they look fixed i have tried in case though. Trying to wack it any further through the hole is just going to wedge it in tighter as there isn't any clearance. I was wondering if I was missing something ( a hidden bush or necessary alignment trick) but have no reference diagrams and figured i would stop before I make it worse.</p></blockquote><p></p>
[QUOTE="whale156, post: 627334, member: 31995"] [url=https://postimg.cc/VdvNSC1M][img]https://i.postimg.cc/VdvNSC1M/20210620-134642.jpg[/img][/url] Thanks. Here is a closeup of mine after i took the pedals off and tried to persuade the shaft out, I managed to bash it a few inches before it seizes tight (even this would not have been possible with the floor fitted). There is a bit of a key/tab on each end of the shaft which you might just make out on the visible end. I can't remove these so far as I know though since they look fixed i have tried in case though. Trying to wack it any further through the hole is just going to wedge it in tighter as there isn't any clearance. I was wondering if I was missing something ( a hidden bush or necessary alignment trick) but have no reference diagrams and figured i would stop before I make it worse. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Gallery
