hey 13 windows.... nah mate.... as above... SA sprints.... or Rostyles as they are really called!
no drop spindles or narrowed beams here... just a single foksey adjuster and a 2 spline drop on the back!
cant afford anything more expensive than that!!!
doesnt quite look like this now.....copied this straight from my club forum....
so what have i been doing recently....
well last year i treated the bus to a set of waistline deluxe trim and to follow that i sold my deluxe bumper trim and fitted the bus up with some over riders instead!
chuffed as beans with the look.. so also got myself a set of US plates too!
aaannnnnyway... that was last year and shiney stuff.... but 'this year i haaaaave been mostly sortin' the more important (dull) things...
first off it was up to brians to get the engine sorted...turned out to mostly be bad points gap... but at the same time split manifold boots were diagnosed.... brian also gave me a oil bath air filter which i have now fitted!
got the van to my folkd last week and got to work...
turned out the manifold boots were split clean into 2 pieces!!! they were promptly changed as were the sparkplugs and heater hoses.
following this the i stripped the interior clean out!
then jacked it up and sorted the play in the steering and greased all my nipples!
whilst it was in the air i took the air grinder and did something that ive been meaning to do for a looong time....
i have a foksy adjuster on my front beam...which some will know is located on the top tube...
i find this ridculously hard to adjust as when you have it back down on the wheels to the right height you want you then have to scramble underneath to tighten it back up....but if ya bus is low and you are slightly wider than most like me.... this can be nigh on impossible!
so with the air grinder i cut an access hatch in the cab floorright above the adjuster!!!!
GENIUS!!! i cant believe no-one has ever thought of this before!!! now i can fiddle with the ride height with the greatest of ease!!!! genius!!! i then fashioned a cover that fits neatly back over it!
i then turned my attention to the interior..... which incidentally is sitting in my parents dining room!!
so far i have made some coir carpets similar to the mad matz type but probably a quater of the price as i got a end of roll from trago for 40 quid....a nd enough to do the whole van!!! bargain...
and thats as far as I have got so far as the 'freak' weather has kind of put paid to working outside!!!
