71 bay master cylinder
frenchi
Sep 27, 2013
49
can any one say where the air pipe goes from on master cylinder thanks fellers
hi thanks for that bus came with bits in a box it has a servo at front on shaft there is a pipe like a black concentina just wondering where it goes to as does not show it in the manual any help would be cool
The connection in the front bellows normally connects to a metal stub that exits through the Chassis leg into the front wheel arch, it’s to provide negative air pressure to the servo from memory, it can be left unconnected though
thanks for that what about other hose connection on servo where does that go also anyone have a paire of calipers im in kent
If you mean on the body of the servo then you need to run a pipe to your engine as you need a vacuum feed of the engine ( if it doesn’t already exist), you need to tap a manifold and install a one way valve in the line.
