72 Crossover differences
shaka1976
Oct 2, 2008
23
Ok I've bought a part finished 72 Crossover Danbury.
Now what I want to know is what parts are generally early, which are late and of course those extra special one year only?
I know the basics ie lights and suspension but what about doors, trim, catches, gauges etc
Shak
Danbury Doug
Feb 10, 2007
1,267
Hampshire, UK
Hello Shak. Welcome from a fellow Crossover Danbury owner! :D
Things that spring to mind:
'Early bay': Round bumpers, low front indicators, large VW emblem on front, Volkswagen script on rear hatch, sliding door (handle and mechanism etc), fuel filler flap (although moved further back to clear sliding door this year), instruments, indicator stalk, brake fluid resevoir above kick panel, cab door 'furniture' such as window winder, lock and release levers (chrome), dash heater controls (two red, two blue), grey wiper arms.
'Late bay': Fresh air vents in cab doors, front wheel arches, rear lights, rear vents, Type 4 engines and the modified engine bay and revised engine hatch. Pretty much as you would already know.
It's difficult to specify what was one year only, as some parts were carried over from the earlies and others continued into the lates, ie rear wheel arch profile slightly changed from the '71 model year, and the early style sliding door stayed until the '73 model year etc. I believe some parts to do with the braking system were specific to the crossovers. Others I know of are the front arches, whilst appearing the same as late ones, are slightly different, I assume to take the bumper with step. The rear bumper is crossover specific in that its mounting brackets are different.
I've just mentioned some of the more obvious things, most of which I have discovered myself, having been brought up with a Danbury crossover in the family, but having owned lates, and then recently having renewed my aquaintence with the Danbury crossover by buying the one I have now! :D
There are obviously loads of other detail diferences, some of which I'm sure others will add!
I hope you'll pop some pics up of your bus for us? 8)
Doug
halfpint_fighter
Sep 12, 2007
374
Farnborough
The linkage inside of the rear drum brakes is specific to crossovers and i think the shoes are as well.
The stub axles (or something like that) at the front are as well.
I must admit my rear brakes are now 73 onwards as the linkage was improved :oops:
BigG
Apr 14, 2007
1,227
Suffolk
The crossover front doors had the vents but not the lock button at the top like the lates, the front wheel arches had the early step but the arch was flared and obviously all of the above.
Some unique features include a one off engine lid only seen on early crossovers and the Deluxe beltline trim on crossers differed in as much as it came to a point at the front instead of finishing at the edge of the door. This is because pre 72 an aditional piece of beltline trim was available for the front panel as an extra (rare) which carried on from the doors to make a continuous trim. This was dropped for the crossover hence the point.
The crossovers though available with the type4 engine never had the removable rear valance of the earlier busses or the access hatch above of the late bays though I think some of the very later crossovers did have the hatch.
ground hugger
Oct 15, 2007
1,053
On the road
The gear selector linkage has an extra piece on the end.
they have the early dash top and heater/blower pipes
Danbury Doug
Feb 10, 2007
1,267
Hampshire, UK
I'm not aware of any crossovers having the access hatch above, but I could be wrong. No removable valance like you say.
The pop-up locks, for those who don't know, interestingly were used on the first model year bays, and then dropped until being re-introduced from the '74 model year (or later in the '73 model year) onwards.
I'd forgotten about the difference in the engine lids. I think the difference was the 'lip' or whatever you call it (houses the numberplate lamp) above the numberplate was later extended slightly further to each side if I remember correctly? :)
rustydiver
Oct 24, 2006
1,224
somerset
Mines a late early believe 23rd July 72. Does that make me an late early or a early late :D . I dont have an cutout in the enging comp. I have wrap around bumpers and high indicators up front.
One year only calipers, (which i have a spare set in the garage).
Big rear light with large air intakes.
As a german once told me that VW didnt waste nought they used up all of the bits lying around. Very late earlys hade wrap around bumpers up front and newer style at the rear.
That what makes us crossers special we are all different.
BigG
Apr 14, 2007
1,227
Suffolk
Danbury Doug said:
We're the mongrels of the bay world! :lol:
If we were a cross between earlies and lates then I would except mongrel but we came before lates were introduced so I prefer the word 'mutant' :mrgreen:
Danbury Doug
Feb 10, 2007
1,267
Hampshire, UK
wibbler said:
Danbury Doug said:
True! :lol: I tend to go with 'late early' (as Rustydiver says about his one). Afterall, we're more early than late! :mrgreen:
Blackpony
"Jonathan"
Dec 28, 2017
12
6
Michigan, USA
Year of Van
1972
Van Type
Kombi T2AB Westfalia
Did not know VW did high lights from the factory. High lights replacing low lights front panels are more common with body repairs. AB Crossover information very useful for rebuilding my 1972 T2 Kombi (SO 72/2) 'Westfalia - Los Angeles." Thanks all 🍺
Clem
Administrator
Staff member
Administrator
Oct 5, 2006
8,074
199
Gloucester
I’d agree. I’d say if it’s a genuine 72MY with high indicators then it’s had a new front panel.
fatgaz
May 26, 2015
59
7
Doug
It would also depend where the bus was built for. Mine was exported to Boston USA so as a crossover, low lights on the front, late rear lights, no inspection hatch and a Type 4 engine.
