Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
added air
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Trikky2" data-source="post: 432029" data-attributes="member: 240"><p>It shouldnt need it if the engine is stock - they were designed to cope.</p><p></p><p>If you think the engine is overheating then it would be worth checking with a gauge rather than modifying bodywork.</p><p></p><p>If the gauge does show its overheating then theres something wrong that needs fixing - adding more air is treating the symptom rather than the cause.</p></blockquote><p></p>
[QUOTE="Trikky2, post: 432029, member: 240"] It shouldnt need it if the engine is stock - they were designed to cope. If you think the engine is overheating then it would be worth checking with a gauge rather than modifying bodywork. If the gauge does show its overheating then theres something wrong that needs fixing - adding more air is treating the symptom rather than the cause. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
added air
