Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Advice on front drum removal
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ozziedog" data-source="post: 550491" data-attributes="member: 13810"><p>Hi Lee, you may have to back both adjusters right back until they won`t go no more. That can be a lot of adjusting by the way. I think from memory you can just about see the thread on the adjusters with a nice light through the adjusting hole. You may have to work the adjusters back and forth a few times to make sure the threads are clear enough to get them backed off completely, I don`t think a puller would work until the shoes are backed off completely and then you won`t need a puller. What can sometimes make it worse is the fact that a lot of these drums are very old and sometimes if not mostly they`ll have a lip worn into the drum surface which makes it even more important to back them adjusters off all the way.</p><p></p><p>Ozziedog,,,,,,,,,,,,,, Good luck with the patience and mind your knuckles :mrgreen:</p></blockquote><p></p>
[QUOTE="ozziedog, post: 550491, member: 13810"] Hi Lee, you may have to back both adjusters right back until they won`t go no more. That can be a lot of adjusting by the way. I think from memory you can just about see the thread on the adjusters with a nice light through the adjusting hole. You may have to work the adjusters back and forth a few times to make sure the threads are clear enough to get them backed off completely, I don`t think a puller would work until the shoes are backed off completely and then you won`t need a puller. What can sometimes make it worse is the fact that a lot of these drums are very old and sometimes if not mostly they`ll have a lip worn into the drum surface which makes it even more important to back them adjusters off all the way. Ozziedog,,,,,,,,,,,,,, Good luck with the patience and mind your knuckles :mrgreen: [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
