Advice on installing oil pressure and temp gauges
CPBerry2011
Oct 17, 2013
270
Hi
I have a new VDO Series 1 oil pressure gauge and plan on purchasing an oil temp gauge and was wondering what else I should purchase in addition to the gauges. I have no senders at the moment and found it pretty confusing when I looked. Do I need senders for both gauges (if so how do I match it to the gauge I have?) and do I need any other bits for installation other than wire and a 'mount'?
Merry Christmas.
Chris.
Bobster
Jul 27, 2009
645
Newcastle
Yeah, pretty much as you say and you do need to match the senders go the gauges, you would normally buy them as a complete set.
The temperature sender will either be a dipstick, sump mounted or screw in type and that's all you'll need for that.
For the pressure it all depends. This screws into the pressure dummy light switch and can either have dual outputs meaning that you retain the light or you can add a t-piece allowing both senders to be used.
gas1man
Apr 22, 2012
2,208
175
Dorset
Year of Your Van(s)
1971
Van Type
Dormobile
If you have no luck try EARLY VW on this forum he will help I am sure.
Got both of mine from him.
J & P
:D :D :D
Stevec
Oct 14, 2012
315
Kenley Surrey
I bought off eBay and oil pressure gauge comes with the sender. I bought three between £11-16 each (oil pressure, oil yep amd voltage) all work and look great
Here's the eBay item number
221427920532
Zcat7
Apr 12, 2010
662
3
Oxfordshire
Year of Your Van(s)
1972
Van Type
Crossover
Be careful with the dual sender for oil pressure gauge and light. The oil light trigger pressure on these units is nearly always higher than the standard item (requires more pressure) and hence your oil light will come on more, eg a hot engine at tickover. I ended up fitting a t-piece and the original switch to get around this. This is a widely reported problem.
67 BAY
Oct 10, 2006
696
BARNSLEY
Got mine from the states as it was alot cheaper can't remember who from. Think its a VDO 360-006 But there are different pressures for the oil light connection
CPBerry2011
Oct 17, 2013
270
Thanks for all the input guys. Decided on a temp, pressure and voltage gauge in the end and have ordered the tbar so i can put that system in place if needs be.
Oct 26, 2010
3,247
16
Leeds
Year of Your Van(s)
1971
Van Type
Panel
Be very careful with the T-piece. Actually, just be careful screwing anything in to that part of the case, as it is a weak point.
Screwing anything in there too far or too tightly can crack your case. Sadly I found this out the hard way!
