Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Advice Please - Just Acquired Stock 1600 Engine....
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="smokehouse" data-source="post: 609109" data-attributes="member: 14310"><p>All the above and also always replace the oil cooler seals regardless and if the push rods seals are leaking change those out too. check and see if you have a single carb, which is fine, see if the heat risers are clear so the intake will heat up properly so it won't ice up. Like the guy above said if the end play is awful you might as well take it apart.</p></blockquote><p></p>
[QUOTE="smokehouse, post: 609109, member: 14310"] All the above and also always replace the oil cooler seals regardless and if the push rods seals are leaking change those out too. check and see if you have a single carb, which is fine, see if the heat risers are clear so the intake will heat up properly so it won't ice up. Like the guy above said if the end play is awful you might as well take it apart. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
