Alternator pulley
gagvanman
Oct 24, 2011
529
95
Grantham
Is there an alternator pulley that is slightly bigger than the stock?
I have an aluminium crank pulley which has degrees on it and using the standard fan belt has quite a bit of play in it.
Why not get a smaller fan belt rather than a different alt pulley ?
Why is it loose is your crank pulley smaller than stock?
I’ve found the toothed belts seem to be longer than the V belts of the same size.
I had exactly the same problem, the standard new belt was too loose on my aluminium pully (with the degree marks on), I had no shims in. I then bought a standard pully and it's absolutely fine. Initially 8 shims and now down to 6 after a bit of stretch.
I think the problem is finding a belt that's slightly smaller. I bought a couple and they weren't right, either too tight, or about the same.
Going to have to mark the pulley some how when I do the timing, or maybe just do a static timing?
Tippex is as good as anything but it’s non permanent :mrgreen:
Ozziedog,,,,,,,,,,even permanent marker isn’t really :mrgreen:
