Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
The Lounge
Any plumbers out there...?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="SteveGTU" data-source="post: 591674" data-attributes="member: 3884"><p>Hi Matt</p><p>Don't know if you've resolved this yet but I'd say the coil is trapping air ! The highest of the three pipes in the pic needs to raise towards the vent and yours looks like it goes down then up. Any air would naturally get stuck in the top of the coil and cause the banging noise and stop circulation .</p><p>Set up sounds ok as this was fairly common years ago although if you converted it to a fully pumped system it would be far more efficient</p></blockquote><p></p>
[QUOTE="SteveGTU, post: 591674, member: 3884"] Hi Matt Don't know if you've resolved this yet but I'd say the coil is trapping air ! The highest of the three pipes in the pic needs to raise towards the vent and yours looks like it goes down then up. Any air would naturally get stuck in the top of the coil and cause the banging noise and stop circulation . Set up sounds ok as this was fairly common years ago although if you converted it to a fully pumped system it would be far more efficient [/QUOTE]
Verification
Post reply
EarlyBay Forums
The Lounge
