Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Arrrgh! Are early bay headlights assembly the worst design?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="67panel" data-source="post: 491976" data-attributes="member: 13328"><p>reflector needs to be fitted correct way or bulb will be upside down or sideways ,when bulb fitted gap in terminals should be at the bottom and yes the clips are a bl--dy fiddle,get some one to hold it together as you prise them on.</p></blockquote><p></p>
[QUOTE="67panel, post: 491976, member: 13328"] reflector needs to be fitted correct way or bulb will be upside down or sideways ,when bulb fitted gap in terminals should be at the bottom and yes the clips are a bl--dy fiddle,get some one to hold it together as you prise them on. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
