Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Battery warning light stays on
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="67panel" data-source="post: 623013" data-attributes="member: 13328"><p>It is most likely a faulty diode in alternator allowing currant to back feed, if you dont know a diode is a one way valve for electric. Might be a faulty reg though as solid state . Not likely to be a wiring fault .</p></blockquote><p></p>
[QUOTE="67panel, post: 623013, member: 13328"] It is most likely a faulty diode in alternator allowing currant to back feed, if you dont know a diode is a one way valve for electric. Might be a faulty reg though as solid state . Not likely to be a wiring fault . [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
