Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
General Earlybay Chat
Best Distributor
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="vintagedan" data-source="post: 583782" data-attributes="member: 14849"><p>I use and supply the 123 ignitions, I use them on all of my engine builds with no problems, the ideal one for you is £280.00, 009 are good if you can find one that's not too worn out, it still then needs electronic unit fitting but lacks the vac unit ideally suited to vans.</p><p> PM me if you need any more info.</p><p>Cheers</p><p>Dan.</p></blockquote><p></p>
[QUOTE="vintagedan, post: 583782, member: 14849"] I use and supply the 123 ignitions, I use them on all of my engine builds with no problems, the ideal one for you is £280.00, 009 are good if you can find one that's not too worn out, it still then needs electronic unit fitting but lacks the vac unit ideally suited to vans. PM me if you need any more info. Cheers Dan. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Best Distributor
