Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Biggest engine size with twin 34ICT's
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="K@rlos" data-source="post: 594644" data-attributes="member: 4304"><p>If your going bigger than 1641 the engine will need to be totally stripped and the case machined to accept bigger cylinders so it's not really gonna be a cheap affair... </p><p></p><p>But going back to your original question, I'd not go bigger than 1641 if I'm honest. The cheaper way to get more power would be getting those stock heads ported and matched to the manifolds 1776 onwards needs twin choke 36's as a minimum really.</p></blockquote><p></p>
[QUOTE="K@rlos, post: 594644, member: 4304"] If your going bigger than 1641 the engine will need to be totally stripped and the case machined to accept bigger cylinders so it's not really gonna be a cheap affair... But going back to your original question, I'd not go bigger than 1641 if I'm honest. The cheaper way to get more power would be getting those stock heads ported and matched to the manifolds 1776 onwards needs twin choke 36's as a minimum really. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
