Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
General Earlybay Chat
Blind spot mirror for LHD
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Foz" data-source="post: 343887" data-attributes="member: 17148"><p>I had exactly the same problem, the replacement convex mirror wouldnt fit inside the plastic edging, as it was cracked and split anyway i took the plunge and removed the lot, and stuck the new convex mirror in place with lots of sticky pads....mostly situated around the outter edge of the glass, as the convex of the mirror, and the converse of the mirror frame, make a large gap in the centre which could only be filled with a glue/sealant.</p><p></p><p>As long as you place the mirror centrally when sticking, so the gap around the frame looks even, it doesn't look bad at all!! 8) </p><p></p><p>I'd take pics, but the rain cover is over the bus at the min, and with the impending bad weather due, it wont be coming off till mid week at the earliest!! :roll:</p></blockquote><p></p>
[QUOTE="Foz, post: 343887, member: 17148"] I had exactly the same problem, the replacement convex mirror wouldnt fit inside the plastic edging, as it was cracked and split anyway i took the plunge and removed the lot, and stuck the new convex mirror in place with lots of sticky pads....mostly situated around the outter edge of the glass, as the convex of the mirror, and the converse of the mirror frame, make a large gap in the centre which could only be filled with a glue/sealant. As long as you place the mirror centrally when sticking, so the gap around the frame looks even, it doesn't look bad at all!! 8) I'd take pics, but the rain cover is over the bus at the min, and with the impending bad weather due, it wont be coming off till mid week at the earliest!! :roll: [/QUOTE]
Verification
Post reply
EarlyBay Forums
