lisavx
We finally picked fanny up last night after having even more work done (welding the windscreen and heat exchangers) and were busy planning jaunts and adventures when low and behold I saw that now the brake lights aren't working [emoji31]
The fuses are fine, the wiring seems fine, the bulbs seem fine. There are two switches on the master cylinder so could one have knocked both lights out? Is it an easy fix? Should we take the opportunity to "upgrade" to a mechanical switch and blank the originals out? Could we be missing something obvious and easy to fix?
We just want to get out and use it but seem to be cursed with issues that completely prevent that all the time [emoji22]
Thanks Lisa
Sent from my SM-G955F using Tapatalk
Thanks Lisa
