Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Brake push rod adjustment on a '71, with servo
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="billybradshaw" data-source="post: 74887" data-attributes="member: 299"><p>Morning Jenna,</p><p></p><p>Sorry kid but I've only just seen your post.</p><p></p><p>I decided that the spring problem I had was just because it was 37 years old, I mean after 37 years use I guess things will tend to go a bit floppy...............</p><p></p><p>To get some stiffness back in the spring I heated it with a small blow torch and bent the arm of the spring, i.e. the part which locates in the hole in the bracket that. I'll draw up a pic this weekend and post it so you can see what I mean. It definitely did the trick, the pedal now returns like a good un.</p><p></p><p>Cheers</p><p></p><p>Ian</p></blockquote><p></p>
[QUOTE="billybradshaw, post: 74887, member: 299"] Morning Jenna, Sorry kid but I've only just seen your post. I decided that the spring problem I had was just because it was 37 years old, I mean after 37 years use I guess things will tend to go a bit floppy............... To get some stiffness back in the spring I heated it with a small blow torch and bent the arm of the spring, i.e. the part which locates in the hole in the bracket that. I'll draw up a pic this weekend and post it so you can see what I mean. It definitely did the trick, the pedal now returns like a good un. Cheers Ian [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
