Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Brake upgrades ?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Graham L" data-source="post: 230515" data-attributes="member: 3481"><p>Line locks are normally only used to apply the brakes to one axle leaving the other one free for such activities as burn outs on the drag strip, sprints, hillclimbs etc not sure what the effect would be to use it as a permanent solution as a handbrake?. </p><p></p><p>I know some modern cars use hydraulic handbrakes but normally they have an electrical servo in the way which is acceptable for MOT purposes whereas I'm not sure a line lock on its own would be??</p></blockquote><p></p>
[QUOTE="Graham L, post: 230515, member: 3481"] Line locks are normally only used to apply the brakes to one axle leaving the other one free for such activities as burn outs on the drag strip, sprints, hillclimbs etc not sure what the effect would be to use it as a permanent solution as a handbrake?. I know some modern cars use hydraulic handbrakes but normally they have an electrical servo in the way which is acceptable for MOT purposes whereas I'm not sure a line lock on its own would be?? [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Brake upgrades ?
