Can i run lower??
j.nathan
Nov 18, 2006
212
North Lincs.
I have CSP adjusters in my front beam and i have been running with the amount of drop shown below. Can i run slightly lower without bottoming out the balljoints?
your maximum should be 3.5-4 inches on adjusters, i wouldnt go much lower than you already have. get yourself a set of drop spindles and then you can raise it up a bit to be carreful
Ok thanks.
Didn't think the angle of the balljoints looked sufficient to take another tooth drop, although i see plenty running lower.
On the negative side, i'm a specialised welder by trade and wouldn't run welded dropped spindles if they were giving them away!
Will have to wait until someone makes them in cast.
