Oh.go.on.then
Morning all, can anyone help me out.
I've just installed my new 1776. I wanted to keep it reasonably stock looking so planned to keep the pict 3 off my 1600 with an oil bath air filter. Trouble was when I took the old one off it was a brosol 30/31.
I bought a second hand but almost new euromax pict 3 which reports say should be alright for an aftermarket carb. I jetted it 55idle and 132.5 main, it also has 70 air correction.
The engine started and revved cleanly but wouldn't idle even with the "big screw" (forget what it's called) wound right out!? Anyone know why that might be? Looks like the PO has had a few issues with it as although it looks new you can see all the screws have been tinkered with.
I've put back in my brosol 30/31 with the same jets and it will idle at approx 850rpm but no more. But the "big screw" (must check its proper name) wound almost fully out. Why would the screw need to be fully out?
Trouble is it's a bit disappointing now I have driven it. I know this carb is too small and I do know that a pict 3 is small but I just want low down torque, economy and standard looks. It doesn't go very well though.
Dizzy is a 009 timed at 30deg at 3000rpm and cam is a c25.
That new weber 32/36 I have is looking more appealing by the minute but I'm sure that would be an even bigger can of worms.
Any help gratefully received.
