Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Carb upgrade advice
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="67westy" data-source="post: 577594" data-attributes="member: 14107"><p>Not sure I agree with this. Once they are balanced and setup you should be fine unless you mess with them. Had mine on for 16 months now and not needed to touch them once they were setup.</p><p></p><p>Twin carbs will make the biggest difference. we went for a 1641 when getting a new engine as it all helps but if it were one or the other I'd do the carbs first every time</p><p></p><p>Should probably say this is with the csp bell crank linkage. Maybe other linkages drift?</p><p></p><p>Sent from my Nexus 6P using Tapatalk</p></blockquote><p></p>
[QUOTE="67westy, post: 577594, member: 14107"] Not sure I agree with this. Once they are balanced and setup you should be fine unless you mess with them. Had mine on for 16 months now and not needed to touch them once they were setup. Twin carbs will make the biggest difference. we went for a 1641 when getting a new engine as it all helps but if it were one or the other I'd do the carbs first every time Should probably say this is with the csp bell crank linkage. Maybe other linkages drift? Sent from my Nexus 6P using Tapatalk [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Carb upgrade advice
