Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Charcoal filter canister
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="hart5lizard" data-source="post: 442800" data-attributes="member: 4153"><p>Yes, get your old clothes on, grab a torch limbo underneath & have a good look around, starting from the fuel tank & working your way through as much as you can get to , checking the pipes for dampness which will tell you that your pipe is weeping & needs replacing, my fuel line through the tinware is steel so not so delicate & a bit more maintenance free, maybe yours is the same?</p><p></p><p>But getting the engine out is a fairly straight forward procedure, if your at all worried about what you cant see with it in situ.</p><p></p><p>regards Dan</p></blockquote><p></p>
[QUOTE="hart5lizard, post: 442800, member: 4153"] Yes, get your old clothes on, grab a torch limbo underneath & have a good look around, starting from the fuel tank & working your way through as much as you can get to , checking the pipes for dampness which will tell you that your pipe is weeping & needs replacing, my fuel line through the tinware is steel so not so delicate & a bit more maintenance free, maybe yours is the same? But getting the engine out is a fairly straight forward procedure, if your at all worried about what you cant see with it in situ. regards Dan [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
