Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
General Earlybay Chat
Cheap Fuel Pump relays anyone???
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="dustrat" data-source="post: 504412" data-attributes="member: 20238"><p>Some times you have to bite the bullet and admit that someone has a better idea than yourselve. I said take the live feed from coil to activate relay but bus72 said take it from oil pressure switch, Well in retrospeck after much thought his idea is a better idea for saftey sake. The only minor problem is if you run out of fuel the pump wont work by turning engine over until oil pressure is up. Problem easily solved by connecting feed to coil to fill carb and then putting back on oil pressure switch.. Well bus 72 I've changed my feed over and as you said better safe than sorry !!! Thanks for good tip.</p><p> Robert</p><p> <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite10" alt=":oops:" title="Oops! :oops:" loading="lazy" data-shortname=":oops:" /> :idea: <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="dustrat, post: 504412, member: 20238"] Some times you have to bite the bullet and admit that someone has a better idea than yourselve. I said take the live feed from coil to activate relay but bus72 said take it from oil pressure switch, Well in retrospeck after much thought his idea is a better idea for saftey sake. The only minor problem is if you run out of fuel the pump wont work by turning engine over until oil pressure is up. Problem easily solved by connecting feed to coil to fill carb and then putting back on oil pressure switch.. Well bus 72 I've changed my feed over and as you said better safe than sorry !!! Thanks for good tip. Robert :oops: :idea: :) [/QUOTE]
Verification
Post reply
EarlyBay Forums
