Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Cluch Cable Relplacing
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="67 BAY" data-source="post: 592222" data-attributes="member: 48"><p>Check the shape of the hole at the pedal end where the pin goes (often oval if so weld up ,grind flat and redrill to suit pin)</p></blockquote><p></p>
[QUOTE="67 BAY, post: 592222, member: 48"] Check the shape of the hole at the pedal end where the pin goes (often oval if so weld up ,grind flat and redrill to suit pin) [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
