Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
converting reverse lights for indicators - US Bus
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="chug" data-source="post: 585309" data-attributes="member: 22746"><p>I've just done this on my 71 but i used UK spec rear lights, same principle though.</p><p></p><p>Look at these wiring diagrams https://www.thesamba.com/vw/archives/info/wiring/1968-69Bus_TurnBrake.jpg https://www.thesamba.com/vw/archives/info/wiring/baybus_6869a_headlights.jpg</p><p>keep pin 58 on the rear as a tail light feed, pin 54 feed (black/ yellow and black/ red) take from the rear light unit and connect to the reverse light (reverse feed wire disconnected first).</p><p></p><p>Run a wire from front to back, at the rear connect to now available pin 54 (stop light) and piggy back to the opposite light.</p><p></p><p>At the front is where the 68 wiring diagram looks different to my 71, mine has a hazard switch which i removed the feed from the brake pressure switch (pin 54), i connected this to the new feed to brake lights.</p><p></p><p>On the 68 wiring diagram if you look at item J (flasher relay?) try removing the green wire to pin 54, the one which is fed from items J1 and J4 and connecting this to your new brake light feed.</p><p></p><p>Hopefully that works, there are other ways it's been done, i opted for running a new wire with extras for gauges all in one.</p><p></p><p>Chris.</p></blockquote><p></p>
[QUOTE="chug, post: 585309, member: 22746"] I've just done this on my 71 but i used UK spec rear lights, same principle though. Look at these wiring diagrams https://www.thesamba.com/vw/archives/info/wiring/1968-69Bus_TurnBrake.jpg https://www.thesamba.com/vw/archives/info/wiring/baybus_6869a_headlights.jpg keep pin 58 on the rear as a tail light feed, pin 54 feed (black/ yellow and black/ red) take from the rear light unit and connect to the reverse light (reverse feed wire disconnected first). Run a wire from front to back, at the rear connect to now available pin 54 (stop light) and piggy back to the opposite light. At the front is where the 68 wiring diagram looks different to my 71, mine has a hazard switch which i removed the feed from the brake pressure switch (pin 54), i connected this to the new feed to brake lights. On the 68 wiring diagram if you look at item J (flasher relay?) try removing the green wire to pin 54, the one which is fed from items J1 and J4 and connecting this to your new brake light feed. Hopefully that works, there are other ways it's been done, i opted for running a new wire with extras for gauges all in one. Chris. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
