Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Crank Case
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="alikat" data-source="post: 603521" data-attributes="member: 1013"><p>Auto Linea's case is non heat treated aluminium, and a boat anchor to boot. Zero benefits over mag. Add in Auto Linea's poor reputation for machining cases - usually 30% of the cases have bad cam & crank tunnel alignment (1 in 3 of their boring machines is BAD!). That said, Rima in Brazil let out a run of AS41 mag cases that were truly horrible - fairly easy to spot if you know what you are looking for.</p></blockquote><p></p>
[QUOTE="alikat, post: 603521, member: 1013"] Auto Linea's case is non heat treated aluminium, and a boat anchor to boot. Zero benefits over mag. Add in Auto Linea's poor reputation for machining cases - usually 30% of the cases have bad cam & crank tunnel alignment (1 in 3 of their boring machines is BAD!). That said, Rima in Brazil let out a run of AS41 mag cases that were truly horrible - fairly easy to spot if you know what you are looking for. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Crank Case
