Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Crank Shaft Timing Gear Problem
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Raggles" data-source="post: 591929" data-attributes="member: 20996"><p>Yep ... used a blow torch to apply heat and then some gentle persuasion - wouldn't move at all. I am concerned about applying too much welly as I doubt the crank was made to take that kind of impact. I think I will see if I can't source a gear puller and try again.</p></blockquote><p></p>
[QUOTE="Raggles, post: 591929, member: 20996"] Yep ... used a blow torch to apply heat and then some gentle persuasion - wouldn't move at all. I am concerned about applying too much welly as I doubt the crank was made to take that kind of impact. I think I will see if I can't source a gear puller and try again. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
