So then, having had advice that the hot running of my 1600TP could well be down to the missing little tinware plates that sit between the cylinders, I'm faced with biting the bullet and another couple of air-cooled 1sts for me.
1st time removing the engine, which is of course "just 4 bolts" - yeah right!
But my question is related to cylinder head removal. To fit these little blighters, I need to removed the cylinder heads apparently. So 2 questions - is there any chance they will warp? And I take it the push-rod tubes (currently all non-leaking!) will break their seals - do I need to replace the seals?
While the engine is out, I'mm gonna have a good poke around the tinware, as there's no thermostat fitted, I want to make sure the flaps aren't there in the "closed" position. And I may have a look at the oil cooler - I've also been told that if over-torqued, the seals on that can constrict the oil flow to the cooler.
Any tips greatly received! I do realise that this little endeavour will result in at least 3 new faults
Nick
Nick
