Sittingonthedockofthe BAY
Has any 1 improved this,as mine has now gone out and at first glance the bulb is tiny can this be easily replaced or is there a better method...Rowan.
Tofufi said:(I'm not too sure on this, but have read it somewhere before)
the councillor said:Tofufi said:(I'm not too sure on this, but have read it somewhere before)
what, quasi-technical advice let down only by poor (or imaginary) references ?
*welcome to my world*
Originally posted by Roly
Current needs to be able to flow both ways through the gen light.
Originally posted by MiggyMan
I recently replaced the bulbs in my gauges with led bulbs but because of the hightly directional nature of the led the brighter led bulb was less effective than the original incandescant because the incandescant ""glowed" whereas the led basically shone on the back of the speedo, the solution was simple, i painted the back of the gauge and he inside of the housing white to turn it into a huge reflector which gave a good effect in the end but without doing that the original bulb would have been a far better option!
Pete B said:Don't know about the LED bit, but I think the memory has let you down regarding charging! The dynamo/alternator output is regulated by the, wait for it, regulator/rectifier! ALL the electrical system is run from the battery, the charging system is a separate entity.
Originally posted by Clarkson46
Assuming an external regulated alternator works the same as the internal version, then if the gen light does not come on you will not charge. Start by disconnecting the blue wire from the regulator and connect it to earth with the ignition on, does the gen light come on? If so then you have a problem with the regulator. If the bulb does not come on find out why. Blown bulb, wire off etc.
the councillor said:curses... you've beaten me :evil:
but wait... your references are from... the internet, home of freaks and social mis-fits :shock:
would you accept technical advice from somebody who couldn't spell 'incandescent' ?
:wink:
one thing's for sure though, the fact that you actually rose to the challenge and went off and found the references means that you're either as a) bored or b) dull as me so for that i salute you 8)
the councillor said:well, for what it's worth, my whole 'belief system' is based on grammar*, spelling and mental arithmetic, although it's hard (read impossible) to argue if the dyslexia card** is played.
anybody can get on with a vw bus, you probably don't even have to be able to read, but where do you draw the line ? i reckon organisations like NASA might have quite stringent application requirements...
"i want to go to mars"
can you spell 'incandescent' ?
"in-can-what ?"
get out etc. etc.
going back to the original post and LEDs for a moment, i have no idea if they'd work or not... i've never given the idea a second thought, although i AM considering an LED based trackside scalextric lighting system on the raceway i SHOULD be working on this afternoon instead of spending my time bickering on here... it's just that i know somebody who's done it, and they ARE much brighter than stock, charging and incandescence issues notwithstanding.
now get out and do some welding***
*watching pedants - don't get me started on capital letters
**non-PC expression no offence intended
***i'm a fine one to talk
Pete B said:Think I need to actually read any posts that I reply to so as to not make such of an arse of myself. So often. :roll:
