Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Dash lights fubarred
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Killaybay" data-source="post: 577394" data-attributes="member: 17450"><p>Me again,</p><p></p><p>Instrument panel removed ( see previous post) am running engine to compare brightness of led speedo light to original, when engine cuts out, all dash lights go out, engine wont restart (starter motor running a bit faster than normal), genny and oil lights dont light up when ignition on, wipers wont work. Dash lights are dead apart from hazard tell tale, indicators dont work (only hazards). All headlamps and position lamps ok and dip works.</p><p></p><p>anyone?</p></blockquote><p></p>
[QUOTE="Killaybay, post: 577394, member: 17450"] Me again, Instrument panel removed ( see previous post) am running engine to compare brightness of led speedo light to original, when engine cuts out, all dash lights go out, engine wont restart (starter motor running a bit faster than normal), genny and oil lights dont light up when ignition on, wipers wont work. Dash lights are dead apart from hazard tell tale, indicators dont work (only hazards). All headlamps and position lamps ok and dip works. anyone? [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
