Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Difference in wheel drums?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="DubBGood2Me" data-source="post: 561008" data-attributes="member: 18510"><p>I had a similar issue (if I understand the problem correctly) with some Transporterhaus drums. They were very tight on the splines and if I remember correctly the fitting instructions that came with the drums stated that if they were a tight fit (due to castings) then the splines on the drum would need to be gently 'filed'. This took a while but I eventually got them on and fitted.</p></blockquote><p></p>
[QUOTE="DubBGood2Me, post: 561008, member: 18510"] I had a similar issue (if I understand the problem correctly) with some Transporterhaus drums. They were very tight on the splines and if I remember correctly the fitting instructions that came with the drums stated that if they were a tight fit (due to castings) then the splines on the drum would need to be gently 'filed'. This took a while but I eventually got them on and fitted. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
