Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Door cards stopping them rotting
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ozziedog" data-source="post: 643749" data-attributes="member: 13810"><p>All the above ideas will definitely help. Adding extra drain holes isn’t a bad thought either. Can you have too many drain holes ? If you drill from underneath, you’ll need to clean up the other side of the hole with a large drill bit or similar then coat it inside with whatever you like. But definitely need to make that plastic membrane work and test driving it without the door cards on with a hose or similar to make sure it’s working nicely and not puddling anywhere ,,,, great idea. <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /> </p><p></p><p>Ozziedog,,,,,,,like it like it like it <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="ozziedog, post: 643749, member: 13810"] All the above ideas will definitely help. Adding extra drain holes isn’t a bad thought either. Can you have too many drain holes ? If you drill from underneath, you’ll need to clean up the other side of the hole with a large drill bit or similar then coat it inside with whatever you like. But definitely need to make that plastic membrane work and test driving it without the door cards on with a hose or similar to make sure it’s working nicely and not puddling anywhere ,,,, great idea. :) Ozziedog,,,,,,,like it like it like it :) [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
