M MATTHEW New member Joined Nov 15, 2008 Messages 1 Reaction score 0 Nov 15, 2008 #1 DOES ANYONE KNOW WHAT YOU USE BETWEEN THE DOOR CARD AND VINYL COVERING, WHAT SORT OF LINING AND WHERE CAN YOU GET IT ?
Doris Well-known member Joined Jul 5, 2008 Messages 3,601 Reaction score 3 Location just above the middle Nov 15, 2008 #2 VW originally used thin foam but I suppose the equivilent today would be the thin foam as used under laminate flooring. thin and cushiony and comes on a roll.can br cut easily with scissors as well.
Harlequin Well-known member Joined Jun 16, 2007 Messages 1,746 Reaction score 0 Location South London Nov 16, 2008 #3 its called scrim foam, use the thin one 3mm http://www.woolies-trim.co.uk/c-315-scrim-foam.aspx" onclick="window.open(this.href);return false;
