Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Door drain holes
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Happystamps" data-source="post: 594628" data-attributes="member: 14679"><p>Yup- you don't have doors draining onto the seatbelt mounting area ;-)</p><p>Unless you want to add exterior drain holes, which would be pretty ugly, but that's up to you- protect the inner door with as much rust prevention goop as seems appropriate and keep the drain holes at the bottom clear.</p></blockquote><p></p>
[QUOTE="Happystamps, post: 594628, member: 14679"] Yup- you don't have doors draining onto the seatbelt mounting area ;-) Unless you want to add exterior drain holes, which would be pretty ugly, but that's up to you- protect the inner door with as much rust prevention goop as seems appropriate and keep the drain holes at the bottom clear. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Door drain holes
