Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Dormobile roof jigsaw
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="gninnam" data-source="post: 558128" data-attributes="member: 28874"><p>Did mine many years ago.</p><p>From memory the metal strip on the offside (were it hinges) goes on the inside.</p><p>The rest are on the outside.</p><p>Use Polyurethane sealant as doesn't contain salt etc.</p><p></p><p>Also, don't seal the plastic/metal to the top - when you get it close to being fitted on the bottom, you are supposed to take up any slack by undoing the the top strips and pulling taught (something like that....)</p><p></p><p>Like I said, must be 8 years since I did mine.</p><p>Hope it helps.</p></blockquote><p></p>
[QUOTE="gninnam, post: 558128, member: 28874"] Did mine many years ago. From memory the metal strip on the offside (were it hinges) goes on the inside. The rest are on the outside. Use Polyurethane sealant as doesn't contain salt etc. Also, don't seal the plastic/metal to the top - when you get it close to being fitted on the bottom, you are supposed to take up any slack by undoing the the top strips and pulling taught (something like that....) Like I said, must be 8 years since I did mine. Hope it helps. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
