Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Dynamo to alternator
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="georgeyv" data-source="post: 601612" data-attributes="member: 22226"><p>You'll need the alternator, the backing plate for the fan, the pedestal the fuel pump sits on and also a fuel pump that clears the alternator. Some kits include a spacer for the stock carb too as the wider alternator body can interfere with the carb operation.</p><p></p><p>I got the bits together seperately over a few months because I wanted a Bosch alternator and genuine stand/backing plate.</p><p></p><p>All easy to get hold of. Using an internally regulated alternator means a slight wiring change, but nothing too difficult!</p></blockquote><p></p>
[QUOTE="georgeyv, post: 601612, member: 22226"] You'll need the alternator, the backing plate for the fan, the pedestal the fuel pump sits on and also a fuel pump that clears the alternator. Some kits include a spacer for the stock carb too as the wider alternator body can interfere with the carb operation. I got the bits together seperately over a few months because I wanted a Bosch alternator and genuine stand/backing plate. All easy to get hold of. Using an internally regulated alternator means a slight wiring change, but nothing too difficult! [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
