Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Engine failure
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="jonboylaw" data-source="post: 502022" data-attributes="member: 17621"><p>To be honest, you could spend ages trying to get the chap to to the decent thing, but I doubt he will move. I'd whip the engine out and take the heads off to see what us causing the loss of compression. If you are lucky it could be a couple if exhaust valves that need replacing. These are a piece of piss to do if you can get a valve spring compressor that fits. You can also sort out all that sealant gunk that seems to be on all the joints... </p><p>Not the best news I know, but put it down to experience and try and get it on the road as soon as so you can use it. </p><p></p><p></p><p>Sent from my GX64 SatCom phone using Tapatalk</p></blockquote><p></p>
[QUOTE="jonboylaw, post: 502022, member: 17621"] To be honest, you could spend ages trying to get the chap to to the decent thing, but I doubt he will move. I'd whip the engine out and take the heads off to see what us causing the loss of compression. If you are lucky it could be a couple if exhaust valves that need replacing. These are a piece of piss to do if you can get a valve spring compressor that fits. You can also sort out all that sealant gunk that seems to be on all the joints... Not the best news I know, but put it down to experience and try and get it on the road as soon as so you can use it. Sent from my GX64 SatCom phone using Tapatalk [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Engine failure
