Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Engine out - best jobs to do
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="crede999" data-source="post: 405114" data-attributes="member: 9850"><p>Change spark plugs , check choke, valve clearances , starter bush , check fuel lines / put fuel filter by gearbox , check cv bolts are tight , drop gearbox oil and replace , grease clutch arm and threaded end bit and don't forget to prop your gearbox up before removing engine </p><p></p><p> <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite2" alt=";)" title="Wink ;)" loading="lazy" data-shortname=";)" /> </p><p></p><p>Chris</p></blockquote><p></p>
[QUOTE="crede999, post: 405114, member: 9850"] Change spark plugs , check choke, valve clearances , starter bush , check fuel lines / put fuel filter by gearbox , check cv bolts are tight , drop gearbox oil and replace , grease clutch arm and threaded end bit and don't forget to prop your gearbox up before removing engine ;) Chris [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
