Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Engine rattle up hill?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="rlepecha" data-source="post: 499920" data-attributes="member: 19679"><p>Could you please point me to where VW said this? The Type2.com website states anything above 3-4% is excessive for any engine. Ratwell states it can be tuned from 2-4% at idle.(for a 1970 bus) Obviously 2-3% is more efficient running. </p><p></p><p>The FI type 4 engines were running much less like 1-2% in the states. The FI auto adjust obviously but its clear these engines can run at that level of CO.</p><p></p><p>2-3% at idle would be fine, when the throttle is opened you want 3%-3.5% ish.</p><p></p><p>Sent from my 02_jbla668 using Tapatalk</p></blockquote><p></p>
[QUOTE="rlepecha, post: 499920, member: 19679"] Could you please point me to where VW said this? The Type2.com website states anything above 3-4% is excessive for any engine. Ratwell states it can be tuned from 2-4% at idle.(for a 1970 bus) Obviously 2-3% is more efficient running. The FI type 4 engines were running much less like 1-2% in the states. The FI auto adjust obviously but its clear these engines can run at that level of CO. 2-3% at idle would be fine, when the throttle is opened you want 3%-3.5% ish. Sent from my 02_jbla668 using Tapatalk [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
