Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Engine wont turn
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Gar" data-source="post: 611887" data-attributes="member: 17112"><p>Cheers for the advice. Managed to check connections and still unable to to turn the engine. I gave the</p><p> solenoid a gentle tap with a hammer and lo behold the engine turned but won't fire. I can only turn the engine three times before the battery flattens which suggests something is not right. Need to go through it again <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite3" alt=":(" title="Frown :(" loading="lazy" data-shortname=":(" /></p></blockquote><p></p>
[QUOTE="Gar, post: 611887, member: 17112"] Cheers for the advice. Managed to check connections and still unable to to turn the engine. I gave the solenoid a gentle tap with a hammer and lo behold the engine turned but won't fire. I can only turn the engine three times before the battery flattens which suggests something is not right. Need to go through it again :( [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Engine wont turn
