Exhaust fumes
thejinx
Mar 30, 2011
1,559
73
swansea
I am getting intermittent exhaust fumes into the van. I can’t work out why. I’m running J tubes and have sealed the tubes for the heating system. Any ideas? I did think it was air movement under the van sucking fumes back under the van
Could be tailgate seal damaged or tailgate not shutting properly. There are adjustable stops on each side to make it sit nice and flush when closed. If you are replacing the seal make sure you get a good quality one as the cheap versions don't fit properly and the rubbers too hard to give an airtight seal.
That was our issue - tailgate alignment. Definitely worth checking to make sure that it is giving a good seal all the way round.
