Ok. Here was what I did
Engine running very rich, so
Removed carb changed main jet from 130 to 120. Took opportunity to change fuel lines at same time. Put it back together won't start. Running stock 1600 twin port with 009 dizzy and Solex 30 pict 1 carb bought from Heritage. (It can be used on 1600 twin port)
Checked wiring. Wire running from choke to cut off valve to minus side of coil. Sure it was like that originally although tried it both sides of coil.
2 wires coming from 009 to pos side of coil.
I also, in my capacity as a person who rushes everything and acts without thinking initially unscrewed the idle speed adjusting screw by mistake. Screwed it all the way in and out 2.5 turns. So where should I go next?
Checked I do have fuel getting to carb. Vehicle cranks over but in no way looks like firing.
