Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
fan boosted heaters /demist
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Haveacamper" data-source="post: 389464" data-attributes="member: 2051"><p>i agree that it should not be scorching hot ye.</p><p></p><p>i did think about fitting it inbetween the angel of the north (totem pole) and the antler horns, but then thought about the noise in the cab area???</p><p></p><p>also, if you place it this far down stream of the heater then you will not be able to use the rear facing vent that is positioned in the walkthough.</p><p></p><p>NaFe</p></blockquote><p></p>
[QUOTE="Haveacamper, post: 389464, member: 2051"] i agree that it should not be scorching hot ye. i did think about fitting it inbetween the angel of the north (totem pole) and the antler horns, but then thought about the noise in the cab area??? also, if you place it this far down stream of the heater then you will not be able to use the rear facing vent that is positioned in the walkthough. NaFe [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
