Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
First non-start of the winter, Help please!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Moseley" data-source="post: 611435" data-attributes="member: 20098"><p>Hopefully the noise you're hearing is not as a result of a damaged flywheel. I've seen it on a car in the past that when the starter begins to fail to engage fully, it will begin stripping teeth off the flywheel, to the point where it won't engage, and instead just spins up against the ring gear teeth. Makes a horrible noise. Once your starter is out, you'll be able to see if the flywheel needs replacing also when looking into the starter hole.</p><p></p><p></p><p>Sent from my iPad using Tapatalk</p></blockquote><p></p>
[QUOTE="Moseley, post: 611435, member: 20098"] Hopefully the noise you're hearing is not as a result of a damaged flywheel. I've seen it on a car in the past that when the starter begins to fail to engage fully, it will begin stripping teeth off the flywheel, to the point where it won't engage, and instead just spins up against the ring gear teeth. Makes a horrible noise. Once your starter is out, you'll be able to see if the flywheel needs replacing also when looking into the starter hole. Sent from my iPad using Tapatalk [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
