petesavan
- Joined
- Aug 6, 2012
- Messages
- 17
- Reaction score
- 0
I have a 1968 van and have bought one of those electric windscreen washer systems from JK and have a few questions about connecting it up. Am I right in thinking that the + on the red motor that they supply must be connected to a positive wire under the dashboard somewhere and if so where's the best/easiest place? Could I just tap into the + part of the 12v supply/cigarette lighter socket as that's easily accessible since there's no radio fitted? Also where should the in-line fuse go? In line with the + wire or the - wire? And does the switch/push button go in the + or the - wire? I presume the + but will wait for confirmation.
It looks like the motor has to be bolted or screwed on somewhere using self tapping screws so where's the best/easiest place to do that? They provide a length of new hose with the kit so I guess it's best to use that to replace all of the old stuff as that might be perished somewhere anyway. I'm using the original water container by the way so are there any things I need to know about using that or should it be a fairly straightforward job?
And finally how does air get back into the water bottle as water is pumped out? The original bottle is designed to be pressurised and so would be completely sealed when in use, so does the air just get drawn in through the valve that you use to pump it up, or is some further modification required?
